跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Front camera blurry after cracking screen?
I cracked my iPhone 6 screen and now the front camera is blurry. I thought it was because the glass was cracked in front of camera so I took the glass out that was in front but it is still blurry. Apple can't fix the cracked screen cause my phone is bent. What are my best options to fix the camera?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Your best bet is to replace your front facing camera with another. At the same time you can also replace your bent frame while you are getting your cracked screen fixed. You may ask for free consulting here.
这个答案有帮助吗?
得分 1
1条评论:
I cracked my iPhone 6. After getting it fixed the camera was all foggy and blurry
完成的
添加一条评论
I had this issue several times with my customers. Most of the time by cleaning with alcoholic liquid cleaner or nail polish remover, it will work 100% clear. Make sure you clean the camera lens and exact place where camera stays. Be very gentle while cleaning, because it may crack the part. I am sharing 2 picture with red circles which has to be clean with the liquid i mentioned. Hope it will help. ☺
这个答案有帮助吗?
得分 1
1条评论:
would we have to take off the screen to wipe the camera?
完成的
添加一条评论
Fix your screen so the camera can be better
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maggie Luzier 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 132
总计 76,112
