跳转到主内容
佳能 EOS Rebel T3i 于 2011 年 3 月发布,可以通过其 SKU (SKU:5169BO32) 来识别。这款相机也被称为 EOS 600D 和 EOS Kiss X5,是一款具有1800万像素的佳能数码单反相机。
Replacing internal backup battery of Canon EOS Rebel T3i camera
I am trying to change internal backup-batter of my Canon EOS Rebel T3i Digital SLR Camera. As of now I cant believe that there is no documentation or any information available on internet. I am looking forward to do this thing myself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
7个答案
已选择的解决方案
You cannot change the internal back-up battery of this camera, because it does not have one.
The camera's real-time clock and settings memory are powered by the same battery that powers the camera. A capacitor is used for backup so date/time and settings are retained for a while when the battery is removed from the camera.
See the user manual, p. 34.
这个答案有帮助吗?
得分 2
7条评论:
@flyingdutchman Thanks for your comments.
Till date my date and time was saved when ever I used to remove main battery for charging. But now when ever I remove this battery I loose date and time and I have to set it correctly again.
I called Canon and they said they will charge $300 to change the internal battery.
I am not willing to spend $300 on such a small task.
完成的
This is what I bought from amazon.
Canon EOS Rebel T3i 18 MP CMOS Digital SLR Camera with EF-S 18-135mm f/3.5-5.6 IS Standard Zoom Lens
http://www.amazon.com/gp/product/B004MN0...
完成的
@ashuji2
It looks like either the backup capacitor has died (which is not user replaceable because it's soldered in) or the clock/memory circuit developed a problem resulting in increased power drain (sometimes this happens).
In either case, this is not something you can solve yourself unless you have advanced troubleshooting and repair skills, the latter case might involve replacing an entire board.
完成的
There is a battery. If you look right at the opening of the battery compartment, there are two vertical and one horizontal slits where the internal battery sits. It is very small. The model number is MS614SE. I just disassembled my camera to tinker around.
完成的
@rdcollins912
:) thanks. your comment is filled with hope :) and constructive.
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
There is a battery, its accessible via a small barely visable panel inside the part the battery goes into, just below the the lid catch. Though I removed one out of my worki g camera to test in one that doesnt work and now my camera doesnt turn on. Still trying to find information about it and the batteries are like rocking horse poop, so be aware.
这个答案有帮助吗?
得分 4
2条评论:
Great and, unlike all the other posts by those who have no idea but state false "facts", your answer is correct. It's accessible via an almost invisible door.
Its a MS614S ES cell (Manganese Lithium). it pops out of its holder with a small driver or pin.
The cells are (as you correctly point out) very hard to find. Most of them seem to come with solder tags which are of no use. unless you remove them.
The Canon Part Number is WK1 5174 0000
The battery designation is MS614S ES. If there are letters and numbers after this they denote the welded on solder tags, which you don't want.
Thanks again for a brilliant bit of accurate info.
完成的
My Rebel T3i has a clock battery inside a small compartment inside the main battery compartment. If you look inside the battery compartment on the door side, you will see a small compartment where the battery resides. With a very small screwdriver or knife, simply insert the tool into the slot in the compartment cover. Pry the cover open to expose the battery. Using the small tool, carefully pry the battery out of the compartment.
My battery is marked as a Panasonic MS614. I haven't purchased a replacement yet, as I just removed the old one just now. Whether I can get the battery cover to reclose is yet to be determined. I have read that if the cover won't reclose, it may have to be removed. Wish me luck!!!
完成的
添加一条评论
@ooikamheng see attached photo. Not easy to get to…hope this helps.
这个答案有帮助吗?
得分 1
3条评论:
2020_1021_2032:
Yes, i found the spot, thanks for your photo-gives the better idea.
i used the tweezers to excavate around the edges but can't manage
to slide the tray out :( Need your help to show me how :)
完成的
@ooikamheng I completely disassembled it. I saw no other way to not damage it in the process.
完成的
@rdcollins912
2020_1027_1518:
:( just can't lay hands hard on it yet, unless -
it comes to an end. How convenient it will be, if,
it has a maintenance access or tray to change the button cell-easily
Thanks for your sharing. cool stuff to know.
完成的
添加一条评论
Perfect answer - thanks - we found out this the hard way. The door is fragile.
这个答案有帮助吗?
得分 0
添加一条评论
2020_1020_1103:
rdcollins912 and Bob Bell
Glad that both of you give a hope to my search. I looked through the place around and beneath
the battery lid by using the tweezers and just ended up doubt :(
Would you please show me in PICTURES where is it located and how to open the button cell slot?
这个答案有帮助吗?
得分 0
添加一条评论
I found it in my old 450D. I had to disasemble the front panel and detach the power board but it was tright underneath. I’ll order a replacement part see if it solves the problems I have…
这个答案有帮助吗?
得分 0
添加一条评论
2021_0907_1536:
sometimes,
Things need to crave in to click on the right spot.
my 600D ended up exchanged with the dealer a new set.
And it comes with an working time/Date memory.
no more time/date reset problem caused of built-in button cell :)
Useless when it comes to needed, then i have to open the cast and customize it:)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ashuji2 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 72
总计 11,312
