跳转到主内容
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 个问题 查看全部
PSP not charging. Charge light flashes Orange.
I cannot charge my PSP 2000. The charge light flashes orange when I plug it into my charger. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
10个答案
最有帮助的答案
well try taking it someone like a psp clinic ant try giving them 10 dollars or so to fix it ! keon
这个答案有帮助吗?
得分 1
添加一条评论
Just suck a dick for 5 callers and ho fix it
这个答案有帮助吗?
得分 1
2条评论:
I’s u fucken retarded souds like you got a lot of experience sucking dick to solve your problems
完成的
Lmfao 🤣 😂 😂
完成的
添加一条评论
Probably it's a charger problem. Try with another one
这个答案有帮助吗?
得分 0
添加一条评论
Your Psp is bricked. Reflash with pandora and install cfw. Happen many times to me. Also try going into recovery mode. Forgot how to do that but google it
这个答案有帮助吗?
得分 0
添加一条评论
It happened to my psp 3001 today , when i turn it off light orange light still turns on and it blinks when i charge it, i think the psp had a bug in the system making it think that its still charging from a/c
I fixed it by pluging it to the pc since it also charges when connected to pc, since the psp "focused on the usb charge on pc instead of the a/c charge system error" and there you go its back to normal.
这个答案有帮助吗?
得分 0
添加一条评论
it might be a charger problem
but try and take out the battery then plug your charger to the psp and try to turn it on
if it does then it a battery problem
这个答案有帮助吗?
得分 0
1条评论:
mine's dping it too. it's plugged in now but it's not charging. it turns on when plugged in and battery is not in it.
完成的
添加一条评论
it happened to my psp 2000 today, when i turn it on the light turns into yellow something but when i turned it off i becomes orange
the light becomes black when i charged my psp again and i turned it off and turned it on and whallahh
这个答案有帮助吗?
得分 0
添加一条评论
the psp battery acid is out just get a new battery
这个答案有帮助吗?
得分 0
添加一条评论
It might be a problem with the LCD of the system. Try replacing it
这个答案有帮助吗?
得分 0
添加一条评论
Get a new battery it’s probably broken or ran out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lewis Waddington 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 19
过去 30 天: 122
总计 50,894
