Broken Home Button - Mainboard Failure -HELP
Hello Guys!
The Home Button of my Ipod touch is Broken.
Its very hard to describe, what happened. So I painted some Pictures:
I HOPE You understand what I want to tell you. The Home button itself, is on a little plate. This plate gives a Contact, to the Blue metal Plate on the Mainboard of the iPod. On this blue Colored Place (Of course, its silver in real) is a little metal Spring. This spring is Broken down. I can solder it on the Mainboard, believe me - I can ;) But the Problem is, the Home Button still doesnt work. So I tried to Short circuit the Contact between the Metal Plate and the Bigger Resistor. If you believe me or not, but when I short circuit it, The Ipod thinks I pressed the Home button, The running app will be Closed.
So what now? It seems, there is no Contact between the Metal plate and the resistor anymore. Whan Can I do now?
I dont have a Camera with a high Resolution, that means I can't shot a high Res picture.
Greetings, Kentsfield
Edit: OH HEY! I shot a few pictures, which are - Well, lets say, acceptable.
Original Picture
Edited Picture. YOu can see the Blue place, and the Trace to the Resistor which I meant.
When I short circuit the blue place and the Resitor, the iPod thinks I pressed the Home button.
3条评论
Unfortunately, yes. I am still waiting for a solution for this problem, but I believe that there will never be an answer.
greetZ kentsfield
由 Kentsfield 完成的
Does anyone know where the pad is connected to? on mine the entire pad is lifted and gone, and i can't see any traces coming from it.
由 cj anderson 完成的
cj anderson
- For future reference you posted a comment in the place where only Answers belong. Please use the Add Comment link, or start your own Question.
由 originalmachead 完成的
