跳转到主内容
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 个问题 查看全部
How do I disassemble the screen?
I'm looking to replace the screen with a 1080p panel. How do I go about doing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
just open front screws by removing plastic frame u can replace screen.....do not forget to disconnect battery before u go for it
这个答案有帮助吗?
得分 0
添加一条评论
Have you had any luck doing this? I'm interested as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Damon Sweeney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 313
