跳转到主内容
How can I troubleshoot keys not working
I changed the display assembly following the great guide.
Unfortunately I must have messed up something. The shift keys and a few function keys are not working anymore.
I connected a bluetooth keyboard and it works all fine with that one. I assume that it is some hardware issue.
Is there something I can test before changing the keyboard
Maybe some cables that are not connected
Any idea is very welcome
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Can you give us your systems serial number so we can correctly identify which model you have.
完成的
Dan. The model number is A1370. The Serial number is C02G59XCDJYD.
完成的
添加一条评论
2个答案
try disconnect keyboard strip and try reconnect it back ...if it is a carbon strip clean it with soft dry stuff
这个答案有帮助吗?
得分 0
1条评论:
I"ll give that one a go once I'm back home. Thanks for the suggestion.
完成的
添加一条评论
My preferred way is to load into OSX Apple>System Preferences> Keyboard, check the box "Show Keyboard & Character viewers in menu bar" Click on the new icon and choose Show Keyboard viewer. It'll give you a digital display of the keyboard that will react to each key that you press.
这个答案有帮助吗?
得分 0
1条评论:
I did that one and the keys do not react on the keyboard viewer. They react on Bluetooth keyboard but not on the keyboard
完成的
添加一条评论
添加你的答案
Edward Omagbemi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 873
