跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 Pentalobe Screws Spinning
I have refurbished an iPhone 5 into a "6 mini" housing. Done a few of these, no problems. Had to change the battery in one as it could of done with a new one, one of the screws wouldn't come out and now it spins (so not stripped) but turns to a certain point then clicks
any suggestions? don't really know what else i can do.
no access to the screw other then a screwdriver.
i've used a magnet to make the screwdriver stronger but it didn't work
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try prying up on the screen just slightly as you try turn it out. Sometimes that can push the screw against the edge and get it to come out.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Well. The issue is that the threads of the screw are stripped. Inside the device. So, you could try super gluing your driver to the screw end, and seeing if you can pull it out, probably quickly
这个答案有帮助吗?
得分 1
1条评论:
That would just make it worse, thanks though.
完成的
添加一条评论
添加你的答案
James Carter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 461
