跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your LG TV.
HDMI input looses sync.
LG 42PC3R-TJ Plasma TV looses picture and sound for about 2-5 seconds then brings picture and sound back (sometimes sound is garbled) when a light switch is turned on or off. If I switch from HDMI to component input (RCA red, white, yellow) then the TV is fine. This happens randomly and only on HDMI input.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
Hi,
What type of light is being turned on? If it is a CFL (Compact Fluorescent) then the electronics are probably emitting EMI (Electro-Magnetic Interference) due to either a fault or poor design. It might also be the light switch itself, arcing (thus causing EMI) when it is being turned on or off.
HDMI cables are supposed to have shielding incorporated to prevent EMI from causing a problem.
Suggest you try to isolate the problem by either replacing the HDMI cable and/or the light (try a different brand - I have had 2 of the same type of light (CFL), in the room, but different brands, one causes interference when being turned on, pixellation and sound glitches on my TV when the input source is the antenna. The antenna is in the ceiling space about 5' away from the light - no problems on HDMI though, the other no problems.
If it is neither of the above, you can test the light switch by using a portable radio.Tune it off-station on the AM band, then hold it near the switch, then turn the switch on and off. If there is a problem you will hear it in the radio as a burst of interference each time the switch is closed or opened. If there is, the switch will need to be replaced. You can try this near the light as well, although if you do this before you have changed the light you still mightn't know if it is the light or the switch, which is at fault.
Be aware of the dangerous voltages associated with lights and power in the premises if you need to replace the light switch. If uncertain yourself, call in a professional.
这个答案有帮助吗?
得分 4
3条评论:
Hi Jayeff, thanks for the reply it seems that the suppression on HDMI input has been damaged as my son has been swoping out the HDMI from his playstation and the the decoder without switching off. I figure that static must had done the deed here and the only way to fix this would be to swop out the board which I will have to live with at the moment till I can get a replacement board for it.
Regards
Willy
完成的
Hi Willy,
The EMI still has to be coming from somewhere though. Might be cheaper to find the source and fix that than to replace the board. Just a thought.
完成的
Hi Jayeff, it was not sourced from one light switch but random light switches throughout the house and sometimes when fridge kicks in our out. Lately it seems to have settled down and seems to be working fine. Sorted out wiring in cabinet where decoder and home theater is housed. I also had a spare power surge filter lying around and fitted it. So far so good will keep tabs on it. Thanks for the input, hope this helps other people out there that might have same or similar problems. Enjoy.
完成的
添加一条评论
添加你的答案
Willy Pittner 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 12
总计 1,311
