跳转到主内容
加入维修社区 - 创建账户
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
Battery won't charge even though charge port and battery replaced
I have an iPad 3rd Generation with a power problem. The battery simply will not charge. When I installed a different working charged battery in the iPad, it did turn on but once the battery was drained it wouldn't charge either. I tried replacing the charge port with a known good one, and I checked the data cable and a/c adapter; all were fine. If there is a charged battery installed, everything on the iPad works until the battery is drained, then the iPad is dead. Can anyone tell me what else could be wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
If you have tested with know working parts then the charging system or charging IC chip has failed or other componets on the logic board. This would be a board level repair.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
AZMICROREPAIR 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 194
