跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 个问题 查看全部
How can I swap the battery of my psp go?
How can I swap the old battery in my psp go for a new battery and where can I find it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You can use this guide to get to the battery, though you will have to open the device to get to it. Here is the replacement part.
这个答案有帮助吗?
得分 3
添加一条评论
Use the guide (Chris Green) suggested, if you have a old PS3 controller the PSPgo uses the same battery as the PS3 controllers, you can replace the battery with that one if you cant get a replacement.
这个答案有帮助吗?
得分 0
2条评论:
NO you CANNOT use a ps3 controller battery in a PSP GO. I know this because I just tried it, not only is the size different (won't fit in psp go), the CONNECTOR is different!
完成的
Well that solves everything.
完成的
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 4,207
