跳转到主内容
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
charging port is malfunctioning
re: 7th gen. ipod nano. does not always charge. requires a rubber band contraption to keep lightning cable connected charging ipod. I'm assuming the port needs cleaning/repair/replacement?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
You should start by trying a new charge cord . if that brings no joy then you may need to replace the charging port. this teardown guide can help you through the process .
iPod Nano 第7代拆解
Hope this helps
这个答案有帮助吗?
得分 5
1条评论:
were can i get my ipod nano fixed
完成的
添加一条评论
Is the charging port soldered or plugged in? Thank you,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jill McClure 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 7,719
