跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
iPhone won't turn on
So I had a friend that dropped his phone in a pool and I put in a new logic board and battery. The phone worked fine, since all damaged parts were removed. Then one day I shut it off, and it wouldn't turn on. I lifted the logic board off the battery, put it back on, and it booted up fine. Now I turned it off again, and even after lifting the connectors apart, it still won't turn back on. Any suggestions on anything I should try?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
If you can't get it to turn on by plugging the USB cable into your computer, you need to replace the dock connector.
Replace the 30-pin docking port assembly in an iPhone 3G and fix problems connecting to USB devices, charging problems, loudspeaker audio, and microphone functions.图片
产品
iPhone 3G Dock Connector
$9.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,034
