跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
MacBook don't turn on
MacBook display has no picture after turn it on.
I don't hear any fan or hard disk activity sounds.
the sleep light doesn't turn on.
The computer doesn't seem to have any power when you try to turn it on.
Battery is full; and I tried to switch and/or remove both of ram sticks; no effect.
I tried the SMC reset too.
About the power : the light on the original power cord doesn't turn on green or yellow when plugged on magsafe; but if I use the cord from my new PBpro, it turns on green.
That's it.
Any help ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
That's not good. worst case scenario, your Logic Board may be bad, or maybe your DC in board may be faulty. You should replace the DC In board first and if that does not remedy the situation then you may have a short on the board. Here is the Part I would replace first.
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
Thanks for help.
The battery is full, the MacBookPro cord plugged on the MacBook looks working.
I have another MacBook (1 year older) that presents exactly the same syntoms.
400$ for a new logic board. Hum...
这个答案有帮助吗?
得分 0
添加一条评论
So, with patience, I finally found a afordable logicboard and replace it.
Now, let's wait for the MBP logicboard prices...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anne guillaume 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 1,711
