跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
New Digitizer Not Functioning Properly After Repair
I have replaced my front digitizer per all instructions and even some advanced research and everything looks to be perfect, triple checked connections and adhesives. If I close the screen almost to the point of being fully secure the bezel everything works fine, full functionality. As soon as I apply pressure to panel to be fully secured with ipad bezel, it will continually function as if something is applying pressure to the front side of the screen as if someone is continually typing but they are not and it will just continue making the ipad unusable. I have triple checked any touch points on the back, but the copper portion of the backside of the screen will inevitably touch the rubber padding. Not sure what else to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
As a last effort, before attempting a new digitizer, try applying Kapton Tape along the edges of the inside of the digitizer, over the copper.
I've heard of this helping with these 'ghost touches' you're experiencing. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank Carzo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 98
