跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
To repair must first power off but screen slide doesnt work
Your replacing battery instructions reads:
"This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery."
OK but to reopen and try to fix it, first I need to POWER OFF', There is no way to do it since the screen is totally unresponsive, it shows those while lines.
So PLEASE let me know a SURE way to power off. Thaks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks for the tip about "power OFF". However even after repeating the whole step by step I did to replace the battery, the screen is still unresponsive. I can see a faint grid and both slides to "UNLOCK" and "POWER OFF" don't work. What can I do next? If I knew that "the easy battery replacement" could make the phone unusable I would never even attempted to do it. :-(
完成的
添加一条评论
1个答案
已选择的解决方案
Press and hold the Power and Home buttons simultaneously until the screen goes blank. Then it's powered off.
这个答案有帮助吗?
得分 3
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 46
