Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
Are you using a apple certified charger? Charge with a diffrant charge cord and block see if that helps. You could need a new charge port or the charging IC has been damaged from using non certified charger. Take to your local repair shop for dignistic.
