跳转到主内容
加入维修社区 - 创建账户
An Android 4.2 smartphone released July 1, 2014.
Why doesn't the light turn red when when charging? no led light
Why doesnt the red light work while the phone is charging..and the LED light does not work for notification either..could it be damaged!?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Does the LED turn to green when the phone is fully charged?
Does the battery symbol in the notification area, display values from 100% down to low% then back to 100% when the phone is in use and then when it has been fully charged?
If the LED doesn't turn green, when the phone is fully charged(with the charger still connected) but the phone is working properly, (except for the notification light ,of course) and it can be charged fully as shown by the battery symbol, then yes the LED is probably faulty.
Unless there is damage to the outside of the phone where the LED is, then it is not damaged. It is more likely that it has a faulty or loose connection which prevents it from operating.
You may wish to check to see if your warranty period is still valid. If it is and you wish to make a warranty claim, to get it repaired, contact the manufacturer's customer support section as detailed in the User Guide (Warranty section) that was supplied with the phone
这个答案有帮助吗?
得分 2
2条评论:
Doesn't show green light display on my front
完成的
No jt doesn't.
完成的
添加一条评论
添加你的答案
shangoempress 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 18,611
