跳转到主内容
An Android 4.4.2 smartphone released November 1, 2014.
51 个问题 查看全部
How do I bypass pattern code
How do i bypass the screen pattern lock
回答此问题 我也有这个问题
这是一个好问题吗?
得分 24
9条评论
Blu studio 7.0 asked for pin code
i used 10 1s but still could not log in
please how do i bypass to access my information
完成的
How to unlock pattern lock screen
完成的
Someone set a password on my blue bold phone and I'm unable to use my phone. How do I bypass the password without factory reset and without losing any data?
完成的
i am here asking a question why is one being ask to me
完成的
Hello, I've tried all the videos but they start moving so fast instead of explaining while they're going through it I can't keep up every if I try to rewind and pause, it still is ridiculously fast. Having a brain tumor makes it worse. Is there anyone that will be willing to help me online, through a text, or email, PLEASE?? Thank you.
完成的
显示更多的4条评论
添加一条评论
3个答案
最有帮助的答案
Android comes with protection features like Pattern lock or Password lock to prevent your smart-phone from unauthorized use. But if the owner of the phone is forgot Pattern lock or PIN, then problem arises. I am suggesting you some tricks to recover your lock-
Visit at google.com/android/devicemanager on your phone or computer and sign-in using your g-mail that you used on your lock phone. Under ADM, select the device you want to unlock and then select “Lock”. Then a new window appears and asked for password, you can enter a temporary password into this window and click on “Lock” button. Now you got a confirmation tab window having the buttons Lock, Ring and Erase. Now you can see a password field on your phone, you should enter that temporary password and your phone would be unlocked. Now go to the phone settings and disable the temporary password and change your pattern lock that is easy to remember but typical to guess by others.
If above procedure is not working then try this one-
If you don’t remember your password then enter a wrong password or pattern lock 5 times, a window appears. You should select “Forgot Password”/”Forgot Pattern” option in this window so you would able to open a Google login or backup PIN. Enter either your g-mail login or backup PIN and then You would be able to unlock your phone.
这个答案有帮助吗?
得分 5
3条评论:
How do I bypass a password on a vivo 5 mini?
完成的
How do i bypass pattern lock
完成的
How do I unlock my screen passcode
完成的
添加一条评论
How do break pattern code on a Android blu
这个答案有帮助吗?
得分 1
1条评论:
Factory reset it
完成的
添加一条评论
Factory reset the phone, it should be ready to be switched
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jgh25041963 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 41
过去 30 天: 181
总计 17,769
