跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
What do I need to replace?
So I cracked my screen. It still functions perfectly as if it's not cracked, so I'm wondering what I need to replace.
Although I can see underneath the screen on top of the phone, (near speaker and camera).
I was wondering I could get away with just replacing the glass. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
All you need is:
-New Glass S5
-front screen adhesive
-LCD adhesive
-LOCA glue
-UV light
-mold for Galaxy s5 LCD
-heat gun
-deck of cards
-IPA (clean loca off of LCD)
If your friend has done glass only repairs before he should be familiar on supplies he would need. Those are some of the basics tools and parts needing.
这个答案有帮助吗?
得分 1
添加一条评论
Glass replacements are very difficult but possible, you will have to use heat and some tools to separate the glass from the display, and for the new glass you will need LOCA glue and uv light to adhere the new piece. Using a display and glass combo will be easier but more expensive!
这个答案有帮助吗?
得分 0
2条评论:
I have a friend who has done it many times, so difficulty is no issue. Just, does my description sound like I would be able to just replace glass??
完成的
as long as their is no damage on the display it should be ok, it may just need to be re adhered to the frame
完成的
添加一条评论
添加你的答案
Blairrad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 133
