跳转到主内容
iPad Mini 4 发布于2015年9月9日,有着类似 iPad Air 2 的性能和更小巧的身材。
176 个问题 查看全部
iPad Mini Touch Screen Compatability
Are the digitizer touch screens for the Mini 3 & 4 the same touch screen as on the earlier 1 & 2 models other than the finger print sensors? (which is transferred over) IC connector and all? Or are they different completely. Mainly what I'm getting at is I have a few iPad Mini 2 digitizers here, can they be used to repair the Mini 3 or 4? Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
I dont believe they are. I believe the mini 3 is a different digitzer than the two and on the 4 it might be different as well, but i could not find a part for it! Keep in mind on some of their new ipads like the Ipad air 2 and pro they are fusing the displays to the digitizer so it may be that way on the mini 4, hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the quick reply. Not seeing any Mini 4 digitizers out yet, why I asked. Aware of the Air 2 and Pro using "fused" screen.
完成的
添加一条评论
I know for sure that the iPad mini screens for the 1&2 will not work for the iPad mini 3 because the home button on the 3 is not the same size as the 1&2. The iPad mini 4, I've not seen one of those but thinking the LCD and glass are going to be fused.
Update (01/04/2016)
I think the iPad mini's have little traps in them from Apple to prevent us from repairing them. I think the best guide for repairing the iPad mini is on a website called iPad rehab, google it , and using high quality screens with the copper edges and kapton tape and you will not have any issues.
这个答案有帮助吗?
得分 0
1条评论:
Had a feeling they were not the same. Stopped repairing the Mini here a while ago mainly due to the lcd removal risk. Had 2 or 3 back then in one week, where I screwed up the lcd's on them, so I stopped repairing those. Thought I'd get back into doing the Mini again. Thanks!
完成的
添加一条评论
no, ipad mini 1/2 is same digitizer but ipad mini 3 and mini 4 is different, ipad mini 3 you can change a digitizer by yourself easily, ipad mini 4 you can't, you normally need a lcd digitizer assembly for ipad mini 4, only if you are a refurbished factory have special cut glass tools then you can change ipad mini 4 digitizer.
这个答案有帮助吗?
得分 0
添加一条评论
Yes you can use iPad Mini 1/2 digitizer in iPad Mini 3 but you can’t use the touchID. The iPad Mini1/2 uses the same type and size of plug as the iPad Mini 3. I have tested it and works fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lightspeedssupply 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 36
总计 2,457
