跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
Why is the screen not working?
I just replaced the screen and follow all the instructions. I got a white screen and waited for the battery to run out to reset it. It did. However, the screen does not react when touched. What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Hello,
It could be problem with flex cable, or connector on motherboard. If you've got the old display you could check it. When you gonna put old one with working touch screen and it will work it's something wrong with flexcable on the new display.
-You could check too if flex cable is fully connected.
-You could try to recover ipod with itunes
这个答案有帮助吗?
得分 0
添加一条评论
Hi. I just replaced the front panel of the iPod. Did everything as the instructions. Once the white screen was reset, and came back to normal, the screen does not read the touch or take commands by hand. Nothing happened when it is touch by hand.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
angelito2k 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 52
