跳转到主内容
加入维修社区 - 创建账户
Improved second generation Google-branded tablet with a 7" screen.
Nexus 7 Device Charging Help
Device stopped charging. Replaced charging port and still wont charge. Lock screen does not indicate charging. Tried multiple chargers. Replaced battery and conditions remain the same.
Any advice?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Check you cable try a different usb charger some times the block from asus goes bad and would need replacing
这个答案有帮助吗?
得分 0
1条评论:
I have tried multiple chargers. Ones that work in other devices and it has no effect.
Thanks
完成的
添加一条评论
the asus brick not the cable
这个答案有帮助吗?
得分 0
3条评论:
I no longer have an asus charger brick or cable. I have two other Nexus 7s and they charge with these other chargers. Can I even buy an Asus charger at this point? Should I try that?
完成的
yes ebay carries them cheap
完成的
asus sells the bricks with them because of certain amperage needed to charge the tablet not every tablet take the same amperage
完成的
添加一条评论
添加你的答案
pmcint01 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 143
