跳转到主内容
The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
62 个问题 查看全部
问题已关闭
I want to get rid of a custom os?plz help have tried
I held dowm the three buttons vol up power n home. Android thing came up and asked to choice option. I choice to reboot ph thout it worked but the install os note is still there. Its killing my battery. Need to get rid of it?????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
The latest update was Gingerbread(2.3). The baseband version was: T959VUVKJ6. I did find a copy available for download, Since, I am not familiar with the site, please use your antivirus software to be sure that the file is clean of any viruses. You can also use the firmware baseband firmware to search online as well.
Alternatively, if the current ROM you are using is causing issues, you might also want to review other ROMs available for your phone on the XDA-Developers wiki that may resolve the specific issues you are having. There are many that are based off the stock firmware.
这个答案有帮助吗?
得分 0
添加一条评论
The latest firmware from T-Mobile is: T959VUVKJ6. I found an active link on a personal blog, for that version and I recommend using your anti-virus software to ensure that it is clean from malware.
Also, if your current ROM is causing you problems, the XDA Developers wiki has several alternatives based on stock that might be helpful.
这个答案有帮助吗?
得分 0
添加一条评论
The latest firmware from T-Mobile is: T959VUVKJ6. I found several active links online by doing a search based on the firmware.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 109
