Why Gaggia Espresso Maker/Cappuccino Maker Leaks
Gaggia Espresso/Cappuccino Makers when I open the steam valve and turn on the coffee switch &the steam switch the machine leaks from the everywhere.
Thank you for your help.
Did you read the manual on how to use it or did you just go ahead and try? Maybe it has certain way to close. Just a thought though(and of course no offense intended)
这个答案有帮助吗?
I did read the manual. I did turned on the power switch I timed myself for 6 minutes after I open the valve steam all the way and turned on coffee and steam switch and water start to come out from everywhere not only from the steam tube but also from the valve.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 395
Gaggia Espresso/Cappuccino Makers when I open the steam valve and turn on the coffee switch &the steam switch the macchine leaks from the everywhere.
由 Vittorio Bellini 完成的
