跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Faulty Battery? Apple logo keeps looping ONLY on replacement battery
So the other day I tried to fix my iPhone with the iFixit battery, and not only did some wierd striped lines show up, the iPhone itself would not turn on, instead it would constantly loop through the apple logo and would not restore when I tried it through DFU mode.
Then I put my old battery back in and voila, everything works well (except the battery percent doesnt change, oh well, better than not working at all.) Anyways, this leads me to believe that the iFixit battery is clearly faulty, since it is not a mistake on my part as I replaced it the exact same way as my original battery, and it did not work.
Is there something that I'm missing when I replace the battery? Or do i just have a faulty replacement battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Most likely the battery is ok, sound like pry damage next to the battery conector. When you removed the original battery you might have damaged a few componets on the logic board, it's a very common mistake. There are resistors and capacitors very close to the conector. If you don't have experience with board level repaired take it to your local repair shop for inspection.
这个答案有帮助吗?
得分 0
1条评论:
I can see how that may have caused the problem, however it only works with one battery - the original one, I have replaced and switched them multiple times with the same results.
完成的
添加一条评论
I had a problem with one battery that is a little different, it started out by randomly restarting then it got worse, I was ready to replace the phone when I discovered that it was the battery, I swapped it out and I have had no problem since. I did however put that battery in a different phone and it acted exactly the same. I dont know if this helps you or not but it might.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 79
