跳转到主内容
Also known as the PS one, or the PSOne, this device is the slim version of the original PlayStation, released in 2000.
20 个问题 查看全部
Darkened screen and distorted colors.
Hi! I have a ps one (the remodeled, smaller playstation) and Ive always used it gently. These days I rarely use it, but I always have it ready for use in my room. A month ago I turned it on and the screen looked darkened and the colors somewhat distorted. Videogamewise, the machine works and reads cds perfectly. Could it be a problem with the video output of the machine? Ive tried with different tvs and cables, and the result is always the same. A technician told me that this issue has no way of being fixed, and recommended me to change the motherboard. Is this true? Is there still a way to fix it without changing the motherboard? Thanks for reading! ;)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Thanks! Your suggestions make a lot of sense. Maybe i will take it to a general technician (not a biased, videogames technician) and he will be able to fix the unit. By the way, i just bought a ps in excellent state on ebay for 39 bucks. You were right! :D Thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
Outside in a hot sunny day will not work. Using a heatgun would work but it is probably not the issue and a heat gun will more than likely burn or warp the board since it isn't a controlled heat it will not stop at the 300-600 degrees that would be needed. I think you may have a loose joint on the a/v connector itself. It is possible that the gpu has a issue but loosing color isn't the first thing that I would put on that kind of fault. (Lockups or no startup would be one that would point to it) Another thing to check would be a bad capacitor or resistor. It also could be a setting like progressive scan or ntsc/pal setting. Not sure since I do not have the unit in front of me. I find these systems at goodwill all the time for around 5 to 15 dollars.
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
bernardo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 9,363
