跳转到主内容
苹果出品的高性能平板电脑。
Where are the sleep/wake magnets?
Anyone know where the sleep/wake magnets are located on the iPad Pro? I went through a few cases till I found one I really like, but it doesn't have the sleep/wake function. I added magnets to my iPad air case and was hoping to do the same with this one.
I was hoping ifixit had done a teardown of the smart cover, but I didn't see one, at least not yet.
So....anyone know where to put magnets for the sleep/wake function?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
1条评论
It would appear I'm horribly impatient. I decided to just order a cheapo($8) case with the sleep/wake function off Amazon. Should be here Tuesday, then I plan on slicing and dicing to find the magnet location. I'll post the results when I'm done. Hopefully it'll help the next person looking for the info.
完成的
添加一条评论
4个答案
已选择的解决方案
Case came in today. I tore it open and took some pics.
The red cirles show where the magnets need to be. I estimated the positions on the ipad, so they might be a smidge off, but not much. Polarity does matter, I just flipped till I found the combo that worked. I already modified my case and it works perfect.
Hope this helps someone.
这个答案有帮助吗?
得分 13
1条评论:
Dude.. You saved my life.. Seriously. I have to make my iPad Pro case work with the sleep wake function and nearly had a heart attack when I couldn't find the sensor. I was testing the Smart Cover and was beginning to think I was going to need a ton of magnets to make things work.. All good now. Check out my case though. It's cool.. Thanks! I love you! :) http://youtu.be/2nXEu7bUahA
完成的
添加一条评论
Magnet locations can also be found on the
"Case Design Guidelines for Apple Devices" pdf,
found at the following link: https://developer.apple.com/cases/Case-D...
这个答案有帮助吗?
得分 7
2条评论:
only for iPad pro
完成的
WOW! I checked out the pdf file, the pages with the magnet location diagrams. Lots of minute magnet detail.
完成的
添加一条评论
CHECK THIS OUT!!!!
magnet paper to show exactly where the magnets are
https://youtu.be/hHc2avTFP5Q
这个答案有帮助吗?
得分 0
添加一条评论
i found place of the magnets for ipad pro 12.9 4th gen that can auto wake/sleep the ipad
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CODYORMOE 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 28
过去 30 天: 134
总计 31,047
