Is the GPS likely to be damaged by a hit?
I have an Iphone 6, the GPS is not working and I took it to the service, they said the warranty is not valid since it has a hit in the lower-left part of the telephone and the antenna located there is damaged, Is there a GPS antenna really there ? (close to the earphone plug) or Are they trying to fool me?
4条评论
Hi,
Have you tried GPS out in the open, away from under trees and buildings? It may be losing signal. Just a thought.
由 jayeff 完成的
It could happen.. Is your wifi and Bluetooth working?
由 iMedic 完成的
Yes, everything is working perfectly. Only GPS is failing, and sometimes works. When I use WAZE or Google maps I don't get accurate location
由 Ana 完成的
I usually test the GPS while I am driving and many parts of the city, streets, highways etc.
I have restored the IOS because the first time I took it to service they said the problem was about software and they recommeded to restore, I dit it and the issue was still there, I took it again to service and now they said the issue is related to some hit in the lowest-left part of the phone. I don't trust them since they are changing their diagnostics, I want to know if the reason they are giving me can be real or not otherwise I Can contact customer service and complain.
由 Ana 完成的
