跳转到主内容
Repair and disassembly guides for Kenmore Microwaves.
blows circuit breaker when press start
When I use the microwave feature, the circuit breaker pops. I thought that it was the outlet at first so I tried another outlet on a different breaker, same result. It seems to happen as soon as I want to "nuc" something by pressing start. I do not know how else to describe the issue so I hope that this is descriptive enough. Any advice or input would be greatly appreciated as this device is not that old. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
We have the same issue with Kenmore. It works fine until yesterday. The light and vent are working but when we hit start to heat food, our panel breaker goes off.
完成的
添加一条评论
3个答案
If you have used this in the past and it worked it is likely a bad breaker, bad microwave or you have added something to the circuit to over-load it. If you will let me know how much electrical experience you have I can maybe suggest some ways to narrow it down.
Jim
这个答案有帮助吗?
得分 0
添加一条评论
Since you tried the microwave on two different circuits with the same result I would suggest that the microwave has blown/burned out a component. Since some parts of the microwave circuitry could hold extremely high voltage even when unplugged, this is definitely not something you want to try to repair at home unless you are an electrical engineer or have experience in this area. Take it to a repair shop or buy a new one.
这个答案有帮助吗?
得分 0
添加一条评论
NOT a bad breaker. The problem is the door monitor switch. If it does not activate when the door is closed it places a dead short across the power lines and trips your circuit breaker.
It is either the switch or a worn trip mechanism. Disassemble and insure that the door is tripping the switch when closed. Some MWs are adjustable, some not. If not, replace the plastic tripper. If so, replace the switch.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
virgilv 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 1,815
