跳转到主内容
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71 个问题 查看全部
问题已关闭
IPad 3G connection problem
After a couple of days of using my ipad 3g 64GB I got an indication ''No Service" at the point of the screen where the providers name and the signal strength indication used to be. I did a hardware reset, and a network reset but without success. Also my provider (Vodafone) changed the microsim in order to check if the problem was from the card, but the card was OK. The problem remains the same. Any idea ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Return it. If you just got it a couple days ago then take it back to the Apple Store and they'll replace the defective unit (or diagnose and fix the problem).
这个答案有帮助吗?
得分 0
添加一条评论
if you can wait for a couple of second like less than 30 seconds it will show you a E which means edge connection very slow but it can also show 3G if you are in a big city
这个答案有帮助吗?
得分 0
添加一条评论
i had the some problem.i tested the device with another LCD unit that carries the antenna and worked try it.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,623
