跳转到主内容
Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
19 个问题 查看全部
Micro-USB jack is broken
Ive recently broken the charging micro-usb jack on my h800 headset. At first i could charge if i put it in the right position making it impossible to use and charge the headset at the same time. Now it doesnt want to charge at all and i need to know if it is possible to get the jack replaced or just go buy a new headset.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
It's can be opened, but replacing the USB is not easy unless you have the correct tools.
这个答案有帮助吗?
得分 1
添加一条评论
You have to use hot air gun and iron.
Look near you for some repairing center or just somewhere where smartphones are repaired.
It will cost something about 20$ I think.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matache David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 1,901
