跳转到主内容
苹果订单编号为MC007LL/A / 27" 2560x1440 分辨率的显示器。
Replacing 27" Cinema Display LCD with iMac LCD
I'm trying to replace my 27" Cinema Display's LCD but I'm unsure about compatible panels.
I need LM270WQ1(SD)(B1) but do other panels work too? Like the ones for the 27" iMac?
Btw, it's not the Thunderbolt-version.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
It will work with the iMac display, but you’ll have to transfer the display board and backlight of the old display. I did it and it works great.
这个答案有帮助吗?
得分 3
3条评论:
Hi there' I'm interested to know more on how you did this, I have all the relevant parts etc, and have enough skill to try, please could you possibly elaborate more on what you actual did to get it to work, I kindly await reply.
完成的
but I think I know what you mean.
完成的
I am interested in this solution... I have good known display boards, but did not understand the backlight part of the answer. Do you mean the LCD function cable, or the actual led strip? Can you elaborate?
from what I can tell, the cable that goes to the led strip has the same connector in the two displays...
完成的
添加一条评论
添加你的答案
MacF 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 2,031
