Cause 1
Touchpad and Control Panel
First, ensure that the display works. If the dishwasher display is working but the some of the button don’t respond correctly, the touchpad and control panel might need to be replaced. (Some manufacturers sell the touchpad separately from the control panel. Other manufacturers require that you purchase the touchpad and control panel together. If you cannot replace the touchpad individually, replace the touchpad and control panel.)
Cause 2
Touchpad
First, confirm that the dishwasher display is working. If the display is still working, try pressing some of the touchpad buttons. If some of the buttons respond correctly but others don’t, it is likely that the touchpad is at fault. (Some manufacturers sell the touchpad separately from the control panel. Other manufacturers require that you purchase the touchpad and control panel together. If you cannot replace the touchpad individually, replace the touchpad and control panel.)
Cause 3
Main Control Board
The main control board regulates nearly every function in the dishwasher. If there is a problem with the main control board, it might not send voltage to the dishwasher touchpad, causing the touchpad buttons not to work. Control boards are often misdiagnosed; make sure you test more commonly defective parts before replacing the main control board.
1条评论
Clean light is blinking 7 times and DW won’t start
由 Molly 完成的
