跳转到主内容
Released on October 1, 2013 the BLU Studio 5.5 is an unlocked Android smartphone with two model types being the D600 (single SIM) or D610 (dual SIM).
82 个问题 查看全部
Cannot turn mobile data on
My daughters cannot make any phone calls, nor can she text from her phone. The Mobile Date field is no longer highlighted. Any idea on how to fix that, or what causes that? We just got the phone 4 months ago:-(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Hi,
Are there signal bars at the top of the screen or a red x? If not have you checked that the SIM card is installed properly? If yes can you call the phone from another phone?
完成的
I just got a blu vivo one plus but i can switch on the mobile data network anyone with solution should assist
完成的
添加一条评论
3个答案
最有帮助的答案
Hellow Heike Venturi ,
Check the caller ID on call settings : it should be set as "On" status or "Network default"
Restart the phone and check whether calls can be made.
Above step not related to Data service. best option to contact network operator to check the connection status of your connection.
这个答案有帮助吗?
得分 1
添加一条评论
Oh It Happens Sometimes Go To Settings Then More Then Mobile Network Then Activate Data Connection ( The Solution Of This Problem Is Just Turn The Data Connection At Settings ) I Hope It Works...
这个答案有帮助吗?
得分 0
添加一条评论
i cannot turn on data
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Heike Venturi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 15
总计 12,434
