跳转到主内容
The BLU Energy X Plus has a 5.5 ' HD display, 1GB ram, and an 8mp camera.
42 个问题 查看全部
How can I delete my text messages
I have two Sims and I try to delete messages and they won't delete
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Hello tina rose,
  • Open SMS on your phone and press option button (left side of home button)
  • Select "Settings"
  • Find "Manage SIM card messages "
  • for delete one massage > long press on relevant SMS and select Delete"
  • to delete all "press option button and select "delete option"
Note: steps and options may depend on the currant Android version of your phone
Cheers!
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
Which cell phone do you have? As different sets are having different process on same thing. Still you will try one thing i will suggest you-
just go to the message box and select the message you want to delete. May be when you touch the screen for select the message you want to delete, it shows a option "Delete Thread" or "delete". If it is then click on this option. Your message will be deleted. Otherwise please specify first, which cell phone you are using...
这个答案有帮助吗?
得分 0
3条评论:
i am using blu energy x plus with straighttalk and that didn't work but thanks
完成的
I am using Tecno Spark. Pressing the delete option after highlighting the message, doesn't work. All other options that indicates "delete message" cannot delete the message (s).
完成的
I'm using a techno spark.....can't deleate messages
完成的
添加一条评论
Simple really on the Doro … go to settings, select the delete option and it comes up with options to delete all inbox, outbox, sent and finally all messages. Choose which and press ok.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tina rose 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 20
总计 8,288
