跳转到主内容
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
74 个问题 查看全部
2012 Ford F-150 - Reading text messages with sync system
I was able to bluetooth my iphone6 to the truck for phone calls, however the texts don't come through and it doesn't even make noise to notify that i receive messages.
Can it read them for me?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi,
Hopefully the info and the attached link info is relevant to your vehicle. It is for the Ford Navigation Sync System but the guide keeps stating if equipped, so I'm hoping that yours is.
Turning the text message notification on/off
You can choose to turn SYNC’s text message notification on or off.
To access:
1. Press the PHONE hard button.
2. Select the ‘Settings’ tab on the touchscreen.
3. Select ‘Advanced’.
4. Select ‘Txt Msg Notification’ and turn the feature on or off.
Select ‘On’ to turn text message notification on. With notifications turned on, an audible tone sounds during an incoming text message and response options appear in the display (i.e., view the message, have the system read the message aloud, dial the person sending the message or cancel).
Select ‘Off’ to turn text notifications off. With notifications turned off, you will not be notified by a tone and the incoming text message will not appear on screen.
Here is a link to the Sync Navigation System which may be applicable to your vehicle. Scroll to p.154 for text info. The other option you requested is shown further down the guide.
http://www.fordservicecontent.com/Ford_C...
这个答案有帮助吗?
得分 2
添加一条评论
this feature is phone dependent not car dependent. My 2 Blackberry's never worked and my Motorola Moto X didn't either. My Samsung Galaxy S7 does read texts. Check the Sync site for phone compatibility.
这个答案有帮助吗?
得分 0
添加一条评论
I have an '11 F 150 with the SYNC system. It worked just fine with my iPhone 5....upgraded to a 6s last year and lost the text message notification ability and noise with the upgrade, when I tried to correct it, SYNC says its not a compatible phone. I guess the iPhone 6s is unpopular...lol.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 8,251
