跳转到主内容
Released on October 1, 2013 the BLU Studio 5.5 is an unlocked Android smartphone with two model types being the D600 (single SIM) or D610 (dual SIM).
82 个问题 查看全部
Comes on but is stuck on "BLU bold like us" screen.
Turned phone on and it comes on to the "BLU Bold like us screen." Goes off and continues to repeat the same thing over and over.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 18
9条评论
my phone started turning off and kept doing the same thing and its only showing the blu screen logo... and does this none stop...please help
完成的
it only has factory mode, and it doesn't give me 2 options...help
完成的
My blu phone is frozen on the start up it only showing logo
完成的
Forgot the pin open on my phone what do I do I'm going to disable do I need to use my phone can you show me how to open it thank you
完成的
when i turn on the phone and hold power and both volume butten and it does nothing what is my problem
完成的
显示更多的4条评论
添加一条评论
4个答案
最有帮助的答案
try this and report back
1. Pullout the batter and wait for about 5 seconds then reinsert the batter
2. Press and hold Volume Up + Volume Down + Power key for some seconds.
3. When you see a menu with two options, remove your hand from buttons. Then hold down the Volume Up to enter Android System Recover.
4. Select the "Wipe data / Factory reset" by using the Volume buttons and press the Power key for confirmation.
5. Choose "Yes--delete all user data". Use Volume Down to scroll and Power button to select.
6. select "reboot system now".
allow the phone to reboot it will take some mins to initialize but not forever.... report back with if not succeed.
i will show u how to flash the phone
这个答案有帮助吗?
得分 4
9条评论:
this phone is a blu studio 5.5C
完成的
did you try the above procedure?
完成的
i did n it just show up to half way turning on
完成的
when I hold down the volume and power and menu button it comes up factory mode and gives me 8 options
1. essential test
2. PCBA test
3.full test
4.item test
5.test report
6.signaling test
7.GPS
8. Reboot
I go down to reboot and it still gets stuck on the BLU logo it worked fine this morning then it froze so I took the battery out and restarted and now it wont go back to normal.
完成的
it did nothing to my phone that instruction is &&^& up mn I'm just a poor kid can't get no more phone
完成的
显示更多的4条评论
添加一条评论
It comes on and stuck on bow like us
这个答案有帮助吗?
得分 0
添加一条评论
It comes on and gets stuck on blu
这个答案有帮助吗?
得分 0
添加一条评论
I can't turn on my tablet
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
kimberlyragan35 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 45
过去 30 天: 170
总计 10,652
