跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
4s screen Black and white, fuzzy after change
I changed my cracked screen with a replacement from ebay I got for 20 bucks aud. Everything including touch works fine except for the display. This is what I get:
http://imgur.com/RL7flsu
Is this more likely a faulty lcd or something I've done?
The dimming you see in the picture is not a camera effect. Thats how it looks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Did you take OFF the new screen protective sheet on the back of the LCD? If you installed the screen correctly and perfectly, then you need a new screen.
这个答案有帮助吗?
得分 0
添加一条评论
This can be faulty lcd or you damaged when were replacing... check the connectors.
I will recommend you before replace the new lcd, test it please and connect with out removing old lcd.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simon Di Bella 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 88
