跳转到主内容
I need to fix my blu ray dvd player
Please can you guide me through the problem my bluray dvd is having..the problem is it keeps opening and closing without no one pressing any button and due to this..i cant connect to my aux and play a programme..please what is d solution..thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
It constantly spit's the movie back out. Saying that it's an error.have to repeat the processfor about ten minutes in order for it to actually play. ??
完成的
I chatted with someone on Blu-Ray's chatline. It was determined that my machine needed replacement.
I was sent a shipping bill to paste on the package we sent away. That was about a month ago. We cannot find where it is, why it isn't coming back. We use it to watch Netflix, so we had to cancel Netflix.
Can you help us?
完成的
Can you give us a number to call?
完成的
Your answer is not helpful at all!!!
完成的
If anyone that can fix
完成的
添加一条评论
3个答案
最有帮助的答案
Hi,
Apparently the problem afflicts a lot of Samsung players. The following link shows the problem, but the video itself has no solution. If you read down thru the comments however, there is a solution to fix it. (I realize that it is not your model but as previously stated the problem affects a lot of models).
https://www.youtube.com/watch?v=kZABjfEl...
Pause the video while you read the comments otherwise it will go to the next one when it has finished playing and you will lose the page
Also towards the bottom of the page is a link to another site (see below) which may also assist you. Towards the bottom it has pictures (again not your model, just to give you an idea). In this one the front panel controls seem to be disconnected to stop the problem from happening and then only the remote can be used to control the player.
http://www.avsforum.com/forum/109-home-t...
After all the above it could also be just a faulty Blu-ray drive, not detecting when it is closed. You might just have to try and see what happens, if only to prove it one way or the other.
If you do decide to work on it, please ensure that you have disconnected the power (unplug it) before you start and when you have completed your work make sure that everything is assembled correctly before you reconnect the power. Do not work on it "live". It is dangerous if you don't know what you are doing.
Hopefully this has been of some help.
这个答案有帮助吗?
得分 2
添加一条评论
Samsung is repairing all blue ray players for free. Call their 800 number to set up free shipping and reapirs.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue. Then i open the unit and remove the Touch panel connectors from main board. Now all are working well with remote control but not touch panel. It is the issue for that random opening.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Martins 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 69
总计 21,062
