跳转到主内容
发布于2013年11月22日的微软第三代Xbox游戏主机。
Is it posible to replace the ethernet port?
Im not sure what happened but my ethernet port is no longer recgonizing my cord. Is there any way to fix it at home? (I know for sure that the problem is the port on the xbox)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi,
Couple of things.
1. Have a look with a magnifying glass into the ethernet port and make sure that none of the connector strips have moved out of position, i.e. that they are all straight and parallel.
2. As it might be the controller chip that is faulty, it may be easier to use a USB WiFi adapter so that you can connect your Xbox to your wireless router for internet access, than to try and replace the chip.
这个答案有帮助吗?
得分 2
3条评论:
Ok i check but everything seems in order, it has a built in wifi adapter but for online gaming a wired connection is way better thank you for answering though.
完成的
Hi,
Found this info online, you might have already tried this, if so apologies.
"If this error has still not been fixed..
1. research the make and model number of your router
2. login to the router home page (192.168.1.1)
3. set a dedicated ip to your xbox's mac address
4. reset the router and xbox
5. the error should be restored"
Don't know if it works or not, but it shouldn't take long to set up and try.
It came from this link.
http://forums.xbox.com/xbox_support/xbox...
完成的
Thank you ill try that when i get home
完成的
添加一条评论
添加你的答案
Ramsie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 12,108
