跳转到主内容
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Size of logic board in a1151 and a1229 identical?
Can you put the logic board of the a1151 into the a1229's body?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
You would need to replace a lot of parts, as the connectors on the A1151 are different from those on the rest of the original 17" MBP models. Also, the keyboard and left I/O board, while identical in form factor, are actually incompatible.
这个答案有帮助吗?
得分 3
添加一条评论
Hi Ben
to follow up on the discussion, if I want to change the A1151 board on my MBP by a 1229 (or 1261) board, I will also need to change:
- the left/right fans (or connectors)
- the left/right thermal sensors
- the I/O board
- the keyboard
is there any other parts?
thank you
这个答案有帮助吗?
得分 0
添加一条评论
Then try this one. It says compatible on MacBook Pro 17" Models A1151 A1212 A1229 and A1261
Replace a 2.4 GHz Core 2 Duo logic board (motherboard) compatible with the model A1229 MacBook Pro 17" laptop. Fix processing issues like unexpected shutdowns, reboots, or water damage. Included Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0.图片
产品
MacBook Pro 17" (Model A1229) 2.4 GHz Logic Board
$169.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marius 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,413
