跳转到主内容
HD action camera with touchscreen LCD, released October 5, 2014.
87 个问题 查看全部
How can I replace the touch screen?
I just bought my replacment rear screen yesterday i tried to replace it, but i couldn't remove the original. I could tear down almost totally (i removed even the battery box) but then i stuck. Thanks for any help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
6条评论
Thanks for your answer, but in the meantime i could replace it, and it solved my problem, now its like i have a new camera. It was tricky with that button cable but i made it work.
完成的
How hard was it to replace it? Did you use a tutorial? I can't see to find one online
完成的
Tom - can you please share how you replaced it? I can not figure out how to remove rear lcd without damaging anything and all tear down videos I've watched do not show this being removed.
完成的
I just replaced mine last night. it is glued to the black frame and has to be gently pried and re-glued. You may have to transfer the touch screen on/off toggle switch from the old screen assembly if the replacement you bought doesn't have one. Mine didnt so I had to remove and re-solder the button. Takes some advanced skills to do it but it was very quick and easier than I expected. I did crack my front lcd while removing it but it was already broken and needing to be replaced. It is also glued down.
完成的
Where did you buy the replacement touch screen?
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
You might want to read my additional comments in my topic:
Saltwater drop / Rear LCD not working
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tomi H 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 3,473
