跳转到主内容
Repair guides for feature cell phones manufactured by LG. This category is for phones not using an Android or Windows operating system.
Cant swipe to answer incoming call
Incoming calls on my lg 3 phone are almost impossible to answer. The screen doesn't recognize the swiping motion and freezes up. I also have a red border around the outside edge of screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 30
21条评论
Thanks for the help. I thought the darn thing was broken. Much appreciated.
完成的
A friend of mine explained that a mobile phone touch screen is heat-sensitive. He suggested blowing on your fingers before swiping the dot to answer. Not perfect, but a decided improvement.
完成的
In order to answer a LG Rebel 3 the Accessibility Options Switch on top should be "ON". All of the Switches below it should be "OFF" (including another "accessibility" switch).
完成的
On the LG G5 select - Accessibility - Dexterity and interaction - and switch on Touch and hold for calls. Answer or decline calls without swiping
完成的
i have an LG k4 2017 and i can not answer any calls ,i press the green button and it says swipe the screen but when i do it cuts the caller off can anyone help me solve this please
完成的
显示更多的16条评论
添加一条评论
7个答案
已选择的解决方案
Hi malissa,
Check whether talk back feature turn on your phone
  • In Settings > Accessibility, select Accessibility
  • Set the switch off
Red edge can be removed turn off the developer options
In Settings > developer options > "uncheck all"
这个答案有帮助吗?
得分 11
9条评论:
"Set the switch off." What switch???? What to do here is not at all clear.
完成的
I agree with Ben Myers.
完成的
I have an LG Stylo 3 I have to swipe to answer and it's not recognizing my swipe. I'd much rather change it to another way of answering my calls. Is there a way of changing it?? Can someone PLEASE help me?? I'm missing so many calls...
完成的
I found that I have to hold my finger on the green dot for a second before swiping and then swipe out just an inch or two...it works every time for me
完成的
I'm having the same problem. I will try what Walter said. Thank You.
完成的
显示更多的4条评论
添加一条评论
最有帮助的答案
I have an LG K7. Think it's the Android Lollipop 5.1 .Rarely it would answer, sometimes not. I tapped and swiped the icon repeatedly.
Never read the instructions. Turns out I have to place my finger on the ringing icon and keep my finger on the screen as I move the icon to the right, or probably anywhere on the screen. Just tried it four times, worked every time. So, unknowingly, sometimes I was doing that and sometimes not. That's why sometimes it would pick up and sometimes not.
Hope this helps.
这个答案有帮助吗?
得分 15
14条评论:
Excellent - the "swipe" instruction on the screen is so misleading, but this post was so clear and correct. Thank you, thank you.
完成的
Pretty sad when you can't complete the most basic thing you want to do with a phone...answer it! Thanks for the very clear fix to an important problem.
完成的
Thank you so much! This solves a problem that was drivigng me (and those who called me on my mobile) nuts.
完成的
It's beyond belief that there are no instructions WITH THE PHONE when you first set it up on how to answer it. This is engineering arrogance to the max.
完成的
I agree it's extremely ridiculous that such a basic task was designed to be so difficult. I spent hours trying to find and configure a different Application for my elderly parents. We kept thinking the problem was that they are just two elderly to understand, but then I realized-this is just an idiotic design problem
完成的
显示更多的9条评论
添加一条评论
Go to Settings…..Accessibility……Motor & cognition…..Touch and hold for calls. Turn on to allow answering calls by touching the Answer button without swiping
这个答案有帮助吗?
得分 8
6条评论:
My phone does not have accesibility or cognitive under settings
完成的
Thank you Skpotthast .. finally a 'fix' that works!
完成的
THIS is what I was looking for! Thank you! I haven't tried it yet but it makes perfect sense. Us older folk have trouble with touch screens because our hands tend to be dryer. My previous phone wouldn't answer by swiping but I could press the center button to connect. My new phone has no physical buttons. Thanks again!
完成的
that solved the problem for me, thanx, i almost bought a new phone because it was irritating me so much!
完成的
After years of frustration with my LG phones I finally know the solution. Always just figured it was just me that couldn't answer the phone.
完成的
显示更多的1条评论
添加一条评论
I'm having the same problem. Went to the store, tried it in there and I could answer.
Went home. Instead of swiping I held my finger on the green dot it worked. in the store. However, at home I pressed the green dot and didn't work. This is ridiculous. I have to call back every call. Luckily, I don't get too many. Any suggestions????
这个答案有帮助吗?
得分 3
4条评论:
Just hold your finger on the dot for a few seconds and then swipe and it should work.
完成的
This is ridiculous can't answer phone
完成的
How do you answer the phone? LG Q6 If anyone knows would appreciate an answer
完成的
Maybe we should look into getting our money back, and have a Lawyer be the front man.
I don't want to say the big word (S). This has caused stress for me, to the point where I want to destroy my phone!? , and I am not violent.
完成的
添加一条评论
I have an LG G6. I solved my answering problem. Settings; Accessibility; Dexterity & Interaction; Touch and hold for calls.
Now I can answer or decline calls with a touch or tap. Hope this helps someone. Missed a lot of important calls. Barb Madison 11.24.19
这个答案有帮助吗?
得分 1
2条评论:
YSSS! This definitely works! Thanks! No longer frustrated 😤
完成的
Not when you cannot swipe up to put your pattern in to use your phone
完成的
添加一条评论
I went from Samsung to LG. For over a year, I couldn’t answer calls. I had to call back everytime. The answer button doesn’t work. The phone says swipe to outer ring to answer. That doesn’t work. Oh. Hold the button. I went to settings, accessibility, 2 finger swipe up to answer. 2 fingers swipe down to hang up. My fault. I should have made time to figure this out. The solution is, go back to Samsung or any other company. Have you heard? LG is leaving the phone business.
这个答案有帮助吗?
得分 1
添加一条评论
Ah, my previous solution didn't stick. THIS works for me: before swiping to answer, press and hold the answer button for 1 second, then swipe before letting go.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the tip. I tried this and it worked the first time but never again.  About ready to toss this out the window.
thanks for your help….
完成的
Thank you but that won't work see comments
完成的
添加一条评论
添加你的答案
Melissa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 159
总计 87,535
