Weird keyb.oard issue with my Alienware M14X
I am experiencing the strangest of prob.lems with my MX14 keypadb. So as you might have already realized, there are full stops at the wrong placeb. This is what happens when i press the b. b.utton and the fullstopb. b.utton
When i press the B b.utton the letter b. is followed b.y a full stop and when i press the period key it is followed b.y a b.
This silly thing is tearing my head, any help would b.e appreciated
Hi Jayeff,
Thank you so much for taking time out to helpb. I tried it b.ut it didnt work b.ecause filter option was already turned offb. Thank you very much thoughb.
由 Yatish Suvarna 完成的
Hi,
Can you plug in a USB keyboard and see if you have the same problem when you use it?
由 jayeff 完成的
Hi,
Check to see if you have the Turn on Filter Keys enabled.
Go to Start > Control Panel > Ease of Access > Change How your Keyboard Works > Un checkTurn on filter Keys
=== Update (12/26/2015) ===
Hi,
The info in this link may be of some relevance.
http://www.ofzenandcomputing.com/turn-of...
由 jayeff 完成的
Hi Jayeff,
Thank you for the response b.ut that didn't work
