跳转到主内容
Why is my drone not flying?
It starts but won't take off?
It just flips over on the wheels and by itself it just dosent go up?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
8条评论
Mine has the same issue, its like the propellers are revered. It wont take off, it will only only push downward into the ground, its unusable!
完成的
I have the same issue
完成的
same issue anyone know why?
完成的
me too it just spins backwards all by itself when you take it off on the weels for a few seconds and i think it has to do with balanced weight but at the moment im still trying to figure out whats wrong
完成的
完成的
显示更多的3条评论
添加一条评论
12个答案
最有帮助的答案
The proppellers are mounted in the wrong order. Switch left and right propellers front and back. Had the same problem. The drone was pushing down instead of moving up
http://blog.parrot.com/2014/07/24/how-to...
这个答案有帮助吗?
得分 6
4条评论:
Hi thanks God bless you it works i thought my new drone was spoilt i came here read your started my drone and it came i recommend this to everyone IT WORKS
完成的
hello, thank you your suggestion works
完成的
Thanks a ton! UDAMAN
完成的
Top man. It's working now :)
完成的
添加一条评论
Two propellers angle up and two angle down. Align then in a cross cross pattern so:
front left angle up - front right angle down
back left angle down - back right angle up
这个答案有帮助吗?
得分 4
3条评论:
Thank you so much. This is exactly right!
完成的
OMG this was helpful!!! Thank you!!!
完成的
Thanks it works perfectly
完成的
添加一条评论
Keep switching the propellers and trying it until you get the correct order
这个答案有帮助吗?
得分 2
1条评论:
ok thank you
完成的
添加一条评论
But I figured it out one of your PROPELLERS might be WEAKER than the other ones allowing it to be UN-EVEN. For mines that's what it is but I might need to buy new propellers if you can do that
这个答案有帮助吗?
得分 0
1条评论:
i bought new propellers it still doesn't work
完成的
添加一条评论
yes thats all it does and dont come off the grown just flips foward
这个答案有帮助吗?
得分 0
添加一条评论
My drone typhoon h is not responding to the monitor
这个答案有帮助吗?
得分 0
添加一条评论
My typhoon h drone camera is nor responding to the monitor
这个答案有帮助吗?
得分 0
添加一条评论
No.it goes on it's side. And doesn't fly. It's not mine. It's a friends drone I was using
这个答案有帮助吗?
得分 0
添加一条评论
The wings are rotating but it doesnt fly
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem. I had to put the propellers on again after a crash and I just installed them on the wrong motor. Once in the right position it works like it’s supposed to. Good Luck!
这个答案有帮助吗?
得分 0
添加一条评论
Check the direction of the props. They might have gotten reversed and the 2 same angle props go diagonally to each other
这个答案有帮助吗?
得分 0
添加一条评论
if you press the takeoff button then try lifting up it should work
这个答案有帮助吗?
得分 0
1条评论:
my parrot rolling spider never failed so theirs should be a priority
完成的
添加一条评论
添加你的答案
Isaac Papasidero 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 89
总计 18,358
