Power button flashes but won't turn on.
The power button flashes five time when pushed, then nothing. Removed battery, unplugged left overnight and retried;same results. Worked fine two days ago.
Hi,
This link describes how to "decode" the light flashes from timed pulses to a hex format which will then indicate what the problem is and whether it is in the power adapter, the battery or the system board. Scroll down the page to the section headed by DC IN LED. Hopefully this will help you to isolate the problem.
这个答案有帮助吗?
I opened up the back of the laptop and removed some of the connections... ie: trackpad, finger scanner, side-card slot.
And then my laptop was able to boot and turn on properly and the flashing stopped.
Then i re-connected them, one by one... rebooting each time.
I worked out that the side-card device was causing the fault.
Fortunately I don't use the side card, so I left it unplugged :)
Mine did the same not long after I bought it second hand, it turned out the charger I got with it broke not long after. I found a spare toshiba charger in my Office with the same voltage and plug and it charged and booted up fine. The reason it was flashing was due to "low battery", which makes sense.
这个答案有帮助吗?
Yes, I have the same problem. I have a Toshiba Portege Z30, and and Tecra Z40, both had the same problem from time to time . The battery/power LED contineously flash a few time, pause over and over, does not respond to anything, power button, plug in power supply or anything.
The only solution I found is disconnect the battery and reconnect, that fixes it for a few months and it happens all over again.
The trouble with that is, the battery is inbuilt. It’s a bit of a mission to disconnect the battery. You need to unscrew the bottom cover to get to the battery. This has been a pain in the arse… Never buying any Tos $@$* ba again.
这个答案有帮助吗?
I AGREE ! MINE DID THE SAME TONIGHT . I purchased mine 3 years ago and since day one has had a horrible speaker sound and have had to buy Bluetooth speakers to accommodate. Now this issue and there's nothing I can do no battery out no restart no wait no nothing no more Toshiba for me ever again
i have the statlite but nothing works
Press and hold down, Ctrl - Alt - Delete - Power. For five sec, it stopped flashing and started up after pressing the Power botton
@kenwood42054 You are genius! Thank you.
My power charger works fine. I switched out the 3V 2032 battery that runs the BIOS. Turned on readily after that.
这个答案有帮助吗?
Unplug Power Cable from laptop. Press and hold Power Button and at the same time plug in Power Cable. Release Power button once laptop lights up. It will continue to run on AC power. I recall old phones with removable batteries did the same. I guess manufacturers thought that was the best way to start portable devices?
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 108
总计 96,538
6条评论
good morning house. my tosiba portege z835-p330 laptop only blink yellow light but will not start up at all. has anyone experience something like that here please?
由 Israel 完成的
that page shows nothing
由 Dj Smith 完成的
hi i have a toshiba qosmio g30 153 it wont power on continue sly blinking ornage light i tried with removingbattery and pressing power button for 30 seconds etc still same
由 mohamed mursheed 完成的
You could also hold the power down until the light turns off (think you need to hold it for more than 10 seconds)
由 M A Lee 完成的
Disconnect the battery works, but some Toshiba notebooks, you need to unscrew the bottom cover to do that.
Maybe hold the power for longer (1 minute?). It work for me on the Z40A, Z40B, and Portege Z30A.
由 M A Lee 完成的
显示更多的1条评论
