跳转到主内容
A tablet released by Hisense in 2014, identified by model number E2281.
36 个问题 查看全部
Screen has white static then freezes with colored lines
Hi. My hisense sero 8 screen gets white staticy lines (like an old TV with radio interference) then it just gets colored lines. Sometimes blue screen with white lines and sometimes black with multiple colored lines. It just freezes like this. Turning it off and on helps for a minute, then the same thing happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hi, I have the same problem too. I bought one, liked the Sero 8 tablet so much, I bought another. The first one started to malfunction with horizontal lines, phasing in and out. The second unit after a few on and off sessions, started to phase in and out with horizontal and vertical lines. So it is obviously that these units are defective. I bought my two tablets from Monoprice. What makes it worse is that I also bought cases and likely will have to dump them. If I was rich it would not be a problem. Waste of money and more headaches. Good luck with your situation.
这个答案有帮助吗?
得分 0
1条评论:
HiSense Sero 8: Screen has white static then freezes with colored lines
Hi All,
In the end I decided to return the two defective tables with the erratic lines problem back to the online retailer I bought them from. They covered the shipping. The new tables had different lot-batch-numbers, denoting later manufactured units. The new replacements have thus far worked flawlessly!!! No problems whatsoever.
Thanks to Monoprice for customer service and HiSense for correcting the problem.
I am happy now.
And special thanks to the FixIt site.
完成的
添加一条评论
Hi. My Sero 8 seems to be working OK right now. Last time the lines started (two weeks ago) the tablet was plugged in and I wiggeld the connection and they went away. Hisense says to restart to factory spec, instructions under troubleshooting in owners manual. Hope that helps. Jim.
这个答案有帮助吗?
得分 0
3条评论:
I did the factory reset on the Hisense Sero 8 and the lines still flashes once in a while. This is from the second tablet. The first tablet the lines would stay on for very long periods and then go off. You might have a better unit that is not so affected.
完成的
Hi
I would check and see if your warranty period is still valid. If so, contact Hisense regarding a warranty claim. Here is a link regarding their warranty, http://www.hisense-usa.com/warranty/tabl...
完成的
Hi Jay, I only have had both tablets for 3 weeks now. To send each one back to Hisense is going to cost me about $15. So I rather cut my losses and get a refund and look for something else. I really liked the Hisense Sero 8 -- that is why I am so unhappy!!! It's like a ghost in the unit. It looks like there is a faulty part inside it that is sporadically interfering with screen power. :-(
完成的
添加一条评论
添加你的答案
Jim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 963
