跳转到主内容
Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Ipad is disabled and wont connect to itunes?
Because I entered the wrong code so many times my Ipad says connect to itunes, so I tried and what it kept saying when I tried to sync the Ipad to the computer it says "Enter passcode on Ipad first then sync" However since im disabled on my Ipad i cant. Really appreciate if anyone had a solution thank :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Use this link to reset your iPad:
https://support.apple.com/en-au/ht204306
这个答案有帮助吗?
得分 3
添加一条评论
"you can restore the device on the the same computer that you normally use to sync your ipod. Put the device into DFU mode, then open iTunes. Select your iPod in the sidebar, and click restore. This will restore the device to factory setting but it will DELETE ALL YOUR DATA if you have not backed it up, it will be lost. You put your iPod in DFU by
Turn off iPod
Hold power button for 3 sec
Hold power and home button for 10 sec
Continue to hold home button until iTunes pops up a message telling you that it has detected an iPhone in recovery mode. The screen should remain black
The only other way that I know of that you might try first is to erase the password but I am not sure if this would work when you are already disabled. This will not erase any data on your device. I guess you can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared" you can also check on here My iPod is frozen says I pod disabled?... Hope this helps, good Luck.
这个答案有帮助吗?
得分 1
添加一条评论
reset your ipad by holding off button and click home repedatly
这个答案有帮助吗?
得分 0
添加一条评论
If your ipad is disabled connect to itunes, you can try to use icloud to erase the device. But if you cannot remember your Apple ID and password, you may need to turn to the third-party software such as joyoshare ipasscode unlocker to remove passcode from ipad.
这个答案有帮助吗?
得分 0
1条评论:
but i can't touch the screen of my ipad
完成的
添加一条评论
添加你的答案
Liam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 21,560
