跳转到主内容
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 个问题 查看全部
Red X on battery sign...?! Won't charge!
So I plugged in my charger to charge my Samsung Galaxy Tab 2 7.0 and a red X came up over the power sign! (It is a charger from eBay but I couldn't afford a new one at the time) My cousin had the same problem and just simply restarted her tablet so I tried that but it still didn't work! PLZ HELP ME! (I'm 15, bad use of language!)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Samsung tablets are nutorious for needing the correct power adapter (block) in order to charge. You will find that in some cases the tablet is charging even if the red x is present. Plug your device into the desired power adapter and wait an hour. Next look at your battery percentage. If the battery has charged fast enough for your standards than keep it. But if its charging really slow or not at all then I'd suggest getting a new power adapter. I would suggest getting one from amazon.com. in order to ensure that you buy the correct power adapter, look on your old power adapter to see what the model number is and match it to the one you want to purchase. If you dont have the old power adapter then search for "(device model #) power adapter"
To find your devices model number go to:
Settings/about device/model number
When looking on amazon make sure that the power adapter you are going to purchase says that it is for your device. Sometimes there are products for different devices in the search results.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maddd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,800
