iMac will not power up led 501 is on
Due to my 2 year old boy taking my iphone 6 charger-plugged into imac and then putting the other end into an outlet my imac and most things connected to it have died.
I suspect the motherboard, but I am asking if anyone could confirm that via the last light being lit led 501 the one on the right. No change when i hit the power button.
Thanks for your help
Yes I spanked his little xxxx
13条评论
Yes LCD is plugged in and Ram is still installed
由 Robert2316 完成的
That last LED light is sensing whether or not the LCD is sending/receiving a signal from the LCD. This would lead me to believe that either the LCD itself is out OR the graphics card isn't seeing it for some other reason. Do you get a boot chime?
由 Shmajay 完成的
I do not get a boot chime
由 Robert2316 完成的
Do you hear the HD spin up the OD checking for discs? Any fans spin up?
由 Shmajay 完成的
Nothing spins at all no sound at all
由 Robert2316 完成的
显示更多的8条评论
